(LabviewFpga) Leakage current Data Acquistion with NI9205 module and NI9149 chassis
I am working on a breakdown analysis of semiconductor devices. I want to save the 1s data before the breakdown (look into the past thing). The module has 16 channels and a sample rate of 250ks/s (around 15ks/s per channel). I am trying to trace the rise of leakage current by setting a threshold and then just saving the data if the value is above the threshold using DMA FIFO.  So far, no good results.
Any recommended approach or idea to crack this problem.
(1,638 Views)
Hi kazmi,
What have you tried? Where are you stuck? Why don't you attach your VI?
You may save the whole data, along with the result of the threshold check. In postprocessing you can select the interesting parts of the data...
(1,588 Views)
I want to trace the curve in real time.
My VI is not worth sharing right now.
My idea to solve this task was to get 250ks/s from a channel(if using a single channel), make an array of it, and match the last value of the array to my threshold if condition met I will save the array somehow in DMA FIFO and transfer it to the windows host VI(not sure about that too). Is this idea worth implementing???
But right now I am stuck at the initial step. The problem is if I am getting 250ks/s how can I make an array of them.
(1,572 Views)
Hi kazmi,
can't you use the NI9149 chassis + NI9205 module as a DAQmx device directly from your Windows computer? This way you just need to setup a DAQmx task reading the signals at 250kS/s…
(1,561 Views)
No, actually I have use fpga of NI9149 to acquire data....
(1,558 Views)
