Labview5.0 ->Excel'95
How can I write a table in a specific sheet in Excel'95 using ActiveX or DDE
with Labview 5.0?
(3,194 Views)
Fran,
There is an example that ships with LabVIEW that demonstrates how to use
ActiveX and LabVIEW to write a table to Excel. Just go to the Help Menu,
choose Search Examples, and follow the ActiveX link. You would just need
to modify this example to open a specific workbook and then select the sheet
that you want to add the table to by choosing the "item" method and specifying
the index of the desired sheet, i.e. Sheet1=1, Sheet2=2, etc.
Erin Bray
DDE>with Labview 5.0?
(3,194 Views)
Fran,
have a look to
http://digital.ni.com/appnotes.nsf/f60d3bcb9e8e752185256404007206cb/899fd743
c3f91b18862563df001abd9a?OpenDocument
http://digital.ni.com/appnotes.nsf/web%2Fproduct?OpenView&Start=1&Count=500&
Expand=9#9
There is a application note about OLE. Possible that you can use OLE with
EXEL95.
Fran schrieb in Nachricht <3851233d@newsgroups.ni.com>...
DDE
>with Labview 5.0?
(3,194 Views)
