Labview will not read data from an Excel file that is already open.
I want to read data from an Excel file.  Currently the user specifies the Excel file path, then the New Report.vi creates a template from the file, and then the Excel Get Data.vi reads the data.  This works unless the file is already open.  How can I either read the data while the file is open or close the file?
(3,762 Views)
we can not open 2 instances of same excel file. It will detect that the file is already open and asks for confirmation to discard the previous instance and open new one..........
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,749 Views)
Is the file open in Excel, or is it open because your VI is writing data to it somewhere in your code?
If the latter case is true, you can use a semaphore to ensure that a read and write operation are not trying to occur simultaneously.
Cory K
(3,715 Views)
The file is open in Excel.
(3,706 Views)
