Labview webserver
I build labview project with labview webserver however i could not configure the host default home page.
when i call http://192.168.1.1/hrm/data/index.html it is ok.
I want to call http://192.168.1.1 , i want to call index.html as default. how can i configure for labview webserver. I use labview 2011 version.
(2,396 Views)
Hello davijame01,
I'm not sure that I got your question right, so could you please describe it more detailed?
Have you followed these steps?
If you don't want to write the last part then you can add necessary part in the block diagram using Concatenate Strings Function.
__________________________________________
The best way to thank, is to give KUDOS
(2,238 Views)
