Labview support for ISO 8859-5
HI,
does Labview support ISO 8859-5 character sets?
If yes, then how do i change the default character set in Labview from ASCII to ISO 8859-5?
If no, then which is the simplest way to display russian characters in Labview 6.1 (Labview 6.1 on SuSE LINUX)
Thanks and Regards,
Pavitra
(3,361 Views)
Hi Pavitra,
There is a very easy way to do that in Windows. Start>Settings>Regional and Language Options. Make sure Russian is included as an input language language on the language tab, as well as on the advanced tab where you can specify the language for non-unicode programs.
I have attached a screenshot that demonstrates cyrillic fonts in LabVIEW. The example is done with Bulgarian font, but it should work the same way with Russian. As you can see I have also specified Arial CYR as my font for the front panel and the block diagram.
Try to use the same logic for a Linux system.
Hope that helps!
Kalin T.
(3,345 Views)
Thanks Kalin!
I'll try it out.
Pavitra
(3,335 Views)
