Labview step-by-step pass/failure display
My test does not show the step-by-step pass fail status of each .vi sub-module in a global module.  This happened after several modules were disabled from running and then re-enabled later.  How do I re-enable it?
(2,816 Views)
Your question is impossiblr to answer since no one has any idea of how your code calls the VI, disables them, records results, or even what you mean by a global 'module'.
(2,802 Views)
