Labview sound
Hello everybody!
Is there any way to make Labview 5.1
output a waveform through a sound card
in a continuous loop?
In other words:
1. fill an array (buffer) with data
2. make the sound driver loop on this array !!without!! Labview's DO/WHILE
cycle
Any help will be greately appreciated.
Thank you.
Edward
(2,935 Views)
Edward,
if you have direct access to the windows Multimedia manager, you can play
a file with a continous flag. This can be done with our Multimedia Toolkit,
which is based on the Windows Multimedia Manager (demoa -> www.xon.de)
Peter
"Edward Sazonov" wrote:
>>Hello everybody!>>Is there any way to make Labview 5.1 >output a waveform
through a sound card >in a continuous loop? >>In other words:>1. fill an
array (buffer) with data>2. make the sound driver loop on this array !!without!!
Labview's DO/WHILE>>cycle>>Any help will be greately appreciated.>Thank you.>Edward>>
(2,935 Views)
