Labview serial transmission on USB 6343 DAQ
I am currently working with a NI USB-6343 DAQ device and am attempting to have it communicate with a separate ARM microcontroller. My plan is to have designated digital pins connected to the UART pins of the microcontroller. My question is how in labview do I set up this serial read and write tools? Do I use the VISA toolkit or is it even possible?
(1,992 Views)
You are not going to get that to work with a DAQ.  All you need is a simple RS-232 port for your computer and possibly a 232-TTL or 232-LVTTL converter (depending on your controller).  Then it is simple work with VISA on the LabVIEW side (VIWeek 2020/Proper way to communicate over serial).
(1,976 Views)
So, you're saying that I am not able to physically connect the digital output port of the DAQ in a serial tranmission manner but only through an rs-232 ports straight from my computer will that be able to happen. Do you think it will be possible instead to setup a data bus from multiple digital pins on the DAQ to connect with general IO pins on the controller port?
(1,969 Views)
USB 6343 have only general-purpose DIO, if you were to implement some sort of serial communication using this GPIO, you have to implement the protocol and time it properly, like bit-bang if I have to say in microcontroller terms.
You're better off with a dedicated USB-UART/RS232 converter to make things easy.
Santhosh
Soliton Technologies
(1,961 Views)
And the DIO are software timed, which means you will not be able to consistently get the timing right.  A UART port is the proper tool for this job.  I am personally a fan of StarTech.  If you want a cheaper option, I have had a lot of success at home with a couple of Trendnet TU-S9.  These have RS-232 outputs.  So if your microcontroller wants TTL or LVTTL, you will need to convert it (BB-232LPTTL for TLL, BB-232LPTTL33 for LVTTL).
(1,936 Views)
Looks like Port0 has hardware timing capability up to 1MHz and other ports only static (no way to define the timing exactly between two state changes on a GPIO pin)
Even in this case, I would not recommend using 6343 for anything serial communication protocol. You can save time and effort by getting a USB-UART or 232 cable/convertor.
You can even get NI USB-232 - https://www.ni.com/en-us/support/model.usb-232.html
Santhosh
(1,918 Views)
