Labview search string excel and retrieve data from adjacent cells
I will have an excel sheet with four columns of data, for this we can say A, B, C, D. Column A will contain serial numbers. I need to search for a serial number in column A, and then output the strings from columns C & D in the same row. I understand how to search for a cell containg a string, but not how to then output the data from the other cells in the same row...
Any help greatly appreciated.
LABOR OMNIA VINCIT
(3,769 Views)
There are many ways to do this.  Here is one:
  • Read the data from the Excel Workbook into a N-row by 4-column array.  If the columns are different data types (i.e. A is a string, B is Boolean, C and D are floats), then you may want to instead create a cluster with elements A, B, C, and D and process the Excel data into an Array of Clusters.
  • Now that all of the data are available to LabVIEW, write your Search to get the appropriate Row number, then simply retrieve the C, D column data from the LabVIEW 2D array of cells or 1D array of row clusters.
(3,747 Views)
