‎07-17-2008 02:47 AM
‎07-17-2008 02:52 AM - edited ‎07-17-2008 02:53 AM
Hi Gabi,
yes you need always the runtime to the corresponding development enviroment. Here is the link for the version 6.1 http://joule.ni.com/nidu/cds/view/p/id/746/lang/de.
You can´t convert a vi, which has no diagram.
Mike
‎07-17-2008 03:16 AM
Since you have to recompile the VI for the "new" version, you need the sourcecode. And in LV, the BD is the uncompiled sourcecode. So, if you have no BD or it is blocked by any means, you cannot recompile this VI.
@Gabi1 wrote:
[...] however there is an error opening the files, LV claims that the vi could not be converted since it has no diagram! what does that mean? [...]
‎07-17-2008 03:40 AM
‎07-17-2008 03:50 AM
‎07-17-2008 03:52 AM
‎07-17-2008 04:59 AM - edited ‎07-17-2008 04:59 AM
‎07-17-2008 05:19 AM
i see. So what would be the meaning of ' no block diagram' error, when there is clearly a fonctionality and a diagram to the vi?
@dan_u wrote:
Password protected VIs can be opened and recompiled in a new LabVIEW version. The source code is there, you just can't look at it without the password. But LabVIEW can access it and recompile it and you can even save it in the new version.
Daniel
‎07-17-2008 05:54 AM
‎07-17-2008 01:11 PM
Thanks!
i was totally unaware that one could save the vi withouth the diagram. it does make sense then that it is bound to a RTE and LV version. It seems the developer from whom i inherited this code was pretty possesive about his code source ![]()
talk about making twice the work...
