Labview runtime engine 2014 and window 10
Is there any way how to make runtime engine 2014 version work in window 10 environment?
I know 2014 version does not support win 10. But I must use it.
I have to test an evaluation board and the installer of  GUI application for this board require runtime engine 2014 version.
I have installed 2014 version, first.
But GUI app installer sent pop up message 'runtime engine 2014 is needed'.
The other versions(after 2014) of rumtime engine installed are not recognized by GUI app installer,
I got same pop up message '2014 is needed'.
How can I use runtime engine 2014 version or GUI app of board?
(3,326 Views)
Accepted by topic author ads85
And you are installed the correct bit version of the runtime engine?
Best guest is that you need to install the 32-bit version.
(3,304 Views)
Thanks for your comment.
I checked my computer OS and bit version, win10 64-bit.
According to the OS version, I installed runtime engine for 64 bit.
Considering your comment, what's the next step or checking point needed.
(3,285 Views)
32 and 64 bits are different, just install the 32 bit runtime and it should work. The bitness must match the LV bitness that made the program, not your OS's.
Qestit Systems
Certified-LabVIEW-Developer
(3,279 Views)
The most creasiest way of the "quick bittness check" I've ever seen is to simply open the executable in the default Windows Notepad (I'm serious), then check the first printable characters after the first occurrence of 'PE':
32-bit:
PE  L
 64-bit:
PE  d†
This is how it looks in reality:
(from StackExchange)
or use dumpbin /headers if you have SDK installed.
(3,267 Views)
Thank you so much. I installed the 32-bit runtime engine and it works.
Have a good day. Yamaeda, dkfire and  Andrey Dmitriev.
(3,196 Views)
LabVIEW 2014 and windows 10
According to the official compatibility documentation from NI, Windows 8.1 is the last OS that officially supports LabVIEW 2014. However, it’s not uncommon for older software to function on newer operating systems due to Windows 10’s strong backward compatibility features.
While it’s great that LabVIEW 2014 is working fine on your system, please be aware that this setup isn’t officially supported by NI. This means that while it may work now, future updates to Windows 10 or changes to your system configuration could potentially introduce compatibility issues.
(2,613 Views)
