Labview quits on launch - Mac OS X
Hello. I just installed the Labview 8.6 student version and restarted my computer (Mac OS X 10.5.8). I try to launch the application but it basically quits on launch. It shows up for a second in the dock and then disappears. I really need a way to fix this asap. Thanks.
(3,608 Views)
(3,597 Views)
Hello Nine,
Are you seeing behavior as described in the link muks posted (thanks muks!)? Have you tried rebooting? Unfortunately if you are in a time crunch reinstalling is really the best thing to do, have you tried reinstalling?
With warm regards,
David D.
(3,582 Views)
Well, I tried reinstalling and rebooting, and it still does the same thing. I forgot to mention, it doesn't 'crash' in the typical mac sense. There's no error log, I don't even get that crash window with the cancel/report/relaunch options. When I double click, the icon shows up in the doc for barely a second and then disappears again.
(3,570 Views)
You noted that you are using Mac OS X 10.5.8 which is a supported OS, however what processor type do you have? Only Macs with Intel processors are supported for LabVIEW 8.6, note this KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/42718AE6BE7AD8CE862574C9005B2966?OpenDocument
Did you follow the installation procedure as noted in the release notes here:
http://digital.ni.com/manuals.nsf/websearch/B12D8A2C8CDF279086257436006507EF
Message Edited by Dr. Doiron on 10-29-2009 10:48 AM
With warm regards,
David D.
(3,547 Views)
Yep, my mac's an intel. Specs: 1.83 ghz intel core duo, 1.5gb ram. I install everything the way the release notes say, except I haven't even got a virus detection program to disable (insert mac joke).
Also, my installation process doesn't give me a choice between easy or custom install. And nowhere does it ask for a serial (I got the CD with the labview book and there's a serial on the CD sleeve).
(3,525 Views)
The only textbook I am seeing comes with LabVIEW Student Edition 8.2.1, found here:
http://zone.ni.com/devzone/cda/tut/p/id/6644
In this case this is a known issue, see this KnowledgeBase:
http://digital.ni.com/public.nsf/allkb/BEE49BB55F1C660F8625748F0057D2B3?OpenDocument
Either way with no errors and reinstalling not working I would recommend following the steps in that KnowledgeBase and requesting a new CD, it sounds like there is an issue with that CD.
With warm regards,
David D.
(3,488 Views)
