Labview queue question ?
I have tree vi running in parallel, two of them are supplying data to the
third one using a queue, I would like to know if I need to protect the queue
access with a semaphore for the two vi supplying data ? or si this already
implemented in the queue insert function ?
Gilles
(3,164 Views)
You don't. That's why you have "ms timeout(-1)" input on some of the VI's. Also take a look at "Get Queue Status.vi". You'll notice the outputs "#of ... pending.." which tell you the queue is busy and have those elements pending to be inserted/removed.
(3,164 Views)
You do not need to protect the queue with a semaphore. All messages inserted into the queue will be inserted from wherever they come from... and All will be detected and pulled off.
Michael Aivaliotis
Michael Aivaliotis
VI Shots LLC
(3,164 Views)
