Labview program for connecting WIKA pressure transmitter to DAQ 6212
Hi. I was trying to connect wikai pressure transmitter to DAQ 6212 to read pressure continuously. I have not yet wired it. I was trying to write a labview program. But i was not able to see any option under Analog Input>Pressure>Pressure Bridge. It shows no supported devices found. How should I program this? It would be grateful if anyone can help.
Thank you.
(645 Views)
Pressure Bridge task is for bridge-based pressure sensors. See Measuring Pressure with Bridge-Based and Other Pressure Sensors
To my knowledge, WIKA sensors output voltage or current directly. You can use AI Voltage task and NI-DAQmx Custom Scales to convert from voltage to pressure. See WIKA datasheet for the conversion scale.
https://tmesystems.net/
(613 Views)
