Labview pixelink sdk error
I've a problem with using the pixelink sdk in labview.
I've a PL-A782 camera and I use the SDK 4.1.5 In labview 7.1. When I try to use the "PixeLINK Image in IMAQ - No Vision.vi" from the example vi of the sdk in labview, I get this error :
"Labview : An exception occurred within the external code called by a Call Library Node. This might have corrupted LabVIEW's memory. Save any work to a new location and restart LabVIEW. VI "PixelLINK Image in IMAQ - No Vision.vi" was stopped at node 0xFA38 of subVI "MEPU-Acquisition-GetNextFrame.vi"
I've also try to use the vi "MEPU-Acquisition-GetNextFrame.vi" with an array of sufficient size but I've the same error.
Thanks for helping me.
(3,756 Views)
I found this converstation on the forum, where they talk about more or less the same problem (atleast in the first 2 messages)
Take a look at it and see if it could solve your problem.
http://forums.ni.com/ni/board/message?board.id=170&message.id=256249&requireLogin=False
Kind Regards,
Joris Donders
EMEIA GTM Lead for Semiconductor
www.ni.com/semiconductor
(3,737 Views)
