Labview operator interface and global variable
I have a TestStand Operator interface developed with labview, in its loop I wait for the exit button (not the TestStand Exit control but a simple button control) this event sets a global variable V1; in the meanwhile TestStand sequence is executing a labview step that dynamically executes a VI that  waits in a loop for the V1 (global variable) coming true to exit. If I launch the MMI.vi under development system all it's ok, but if I create the executable the global variable V1 change in the MMI.vi but the VI called from teststand continue to read it (V1) to false. In the build settings I added these VIs like dynamic VI.
Thank you
(3,135 Views)
When you say global variable, you are referring to a LabVIEW global variable?
You dont you use a TestStand StationGlobal.
Regards
Ray Farmer
Regards
Ray Farmer
(3,127 Views)
Yes I mean Labview global variable.
Thank you,
Massimo Ponte.
(3,121 Views)
