Labview opens all VIS in Run mode
LV2013 PDS is opening all VIs in Run Mode.  This is a global problem, not specific to one or a specific number of VIs.
If I create a new VI, save it, close it and re-open it, it's in Run Mode, not Edit mode.  Nothing is set to Run When Opened, nothing is set to be locked without a password.
It's only on this installation; if I take my code to another machine, there's no issue.
I have deleted the labview.INI file, but the behavior repeats itself.
Any ideas?
Message 1 of 10
(4,257 Views)
Check the permissions on the containing folder.  Is something set "Read Only?.  What about SCC?
"Should be" isn't "Is" -Jay
Message 2 of 10
(4,252 Views)
SCC is not configured; I use perforce, but it's not configued to use it or to treat read-only as locked.  I have also checked out all the filed ahead of time with P4, so LV never sees them locked.  The folders themselves are not read-only.
Also, I have created VIs outside of my P4 folder, and I have the same trouble.
Example:
Launch LV:  Create a blank VI (comes up in Edit mode).
Save to Desktop (not within P4 control) as test.VI
Close
Open test.VI ---> It's in Run Mode
I have never seen this happen before.
Message 3 of 10
(4,242 Views)
Example:
Close
Neither have I Smiley Surprised
I'll assume a reboot was attempted and did not change anything.  I would attempt a repair of LabVIEW from the control panel and another restart.
Message 4 of 10
(4,232 Views)
I just ran the SP1 update, so I don't think the repair would help.
I will try it later though.
Message 5 of 10
(4,226 Views)
What is the default program that opens VIs? Is it set to LabVIEW or something else? You can check this by right-clicking on the VI file and going to Properties. Under General you should see the default program under Opens with. You can change this by clicking the Change... button. Just a thought.
Also, can you open the VI in edit-mode from LabVIEW (versus double-clicking from your Desktop to open)?
Taylor B.
Message 6 of 10
(4,205 Views)
Maybe you've already checked this, but this KB talks about setting the VI Properties so that a VI opens in Run Mode:
Setting VIs to Open in Run Mode in LabVIEW
Hope this helps.
Taylor B.
Message 7 of 10
(4,199 Views)
The poster mentioned deleting his LabVIEW.ini.
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(4,167 Views)
Yeah, I checked all the options, including the Locked options.  Seriously have no idea why this is happening.
Message 9 of 10
(4,165 Views)
And that must be frustrating!
To help us reproduce this:
  • Attach your LabVIEW.ini
  • get a Jing account and attach a link to the shared shockwave file demonstrating this behavior
  • attach your LabVIEW.ini file after deleting it again
    • Shut down LabVIEW
    • Delete the ini
    • Open LabVIEW In that order so file settings are not written upon close
    • Verify it still happens
Attach LabVIEW.ini # 3
Actually I'm hoping that you forgot to close LabVIEW before deleting LabVIEW.ini and an obsolete key exists.
Message 10 of 10
(4,160 Views)
