Labview on Linux not recognizing my serial USB device
Hi
I'm new to LabView.
I have installed it on Scientific Linux 6, including NI-VISA. I have an external device which I have configured via visaconf.
The external device comes with drivers that are installed and with a testing program. When I open the testing program, I assume I have to select my device under VISA. But there is no device listed there. Is there anything I need to do to select my device?
Thanks!
Message 1 of 8
(4,429 Views)
Oh, I should also mention that I run everything as root, at least for the time being, to not run into any permission issues.
Message 2 of 8
(4,414 Views)
Can any other Linux program see the port? Are you sure you have the right drivers installed?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 8
(4,365 Views)
Well, I see it under /dev/ttyUSB0 or when I type lsusb. Not sure how to communicate with it otherwise. I'm as sure to have the right drivers installed as I'm sure that the manufacturer pointed me to the right drivers...
Message 4 of 8
(4,362 Views)
Have you actually tried accessing the port? It might not be visible for selection, but still be usable.
Mike...
LabVIEW Champion
Message 5 of 8
(4,355 Views)
What do you mean by "accessing the port"?
Message 6 of 8
(4,351 Views)
Read from it, write to it. Use it.
Mike...
LabVIEW Champion
Message 7 of 8
(4,303 Views)
Yes, I can communicate with it with Python.
Message 8 of 8
(4,282 Views)
