Labview not responding
I don't know how to solve this problem, because I need to run the state machine for 30 minutes, but it only runs for several seconds and then stops. Is it caused by the communication between computer and the equipment, or the computer is not fast enough, or there's some deadlock in the program?
(4,566 Views)
(4,565 Views)
Hi cantata,
which "equipment" are you talking about? Why don't you ask the vendor of "the equipment"? There should be specifications, what kind of computer is needed to drive "the equipment"…
Are your parameters in calling that DLL function correct?
How often do you call that "equipment" DLL?
(4,529 Views)
PS: where's the state machine? All I see is a loop and a DLL call...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,525 Views)
Impossible to say without some real code to look at.
(4,501 Views)
Hi GerdW,
the equipment is a Wave Analyzer. I didn't ask the vendor because I tested this subVI in another simple program and it didn't get stuck.
I have attached my program here. Thanks~
[Edited 04/07/2015: Removed attachment that included private information]
(4,470 Views)
Hi crossrulz,
this is my program
(4,469 Views)
