Labview menus magnify and display for to the right of where they should
While I was looking for an option in the Labview 2018 toolbar menus, some sudden error occurred where the menus became oddly bigger in size and translated to the right like 10 inches on the screen. Choosing options from this dislocated menu still required me to click where the menu would have been normally and at its typical size.
Wondering if this issue can be fixed.
(2,351 Views)
Accepted by topic author jackalakalaka
It appears you're using Windows 10, which has several "scaling" options to make Windows look reasonable when running on high resolution displays.  It's probably a setting related to that.
This support page sounds close to what you describe.  Try those solutions, and maybe update your LabVIEW to SP1 and the latest patch (f3) if you haven't already.
(2,329 Views)
This was exactly the issue--thank you! My small-ish laptop that I use with two additional monitors now requires the occasional squint because I set the same resolution for it as the monitors, but this is much better for Labview.
(2,296 Views)
