Labview linx arduino
Hi everyone
I have problem with arduino and labview I try to make autonome navigation robot for my graduation project and I'm stuck I used linx for the basic mouvement and i can't make it automatically navigate I need a help for planning a path how I do it.
Thank you for your time
(1,596 Views)
Hi Oussama,
Why do you have a problem with Arduino/LabVIEW/LINX?
The problem seems to be the lack of an algorithm for your "autonome nevigation robot"!
I suggest to start with reading books on this matter. Then implement a navigation algorithm!
(Such requests pop up once in a while, maybe you should search the forum for threads about "path planning", "A*", and similar…)
(1,513 Views)
Hey,
The knight is actually right, maybe it's better to check the theory at firs.
There is a good step by step article, It might help.
Good Luck!
(1,442 Views)
