Labview - internal error!
Hello there,
does anyone know somethinge about this failure: "exec.cpp" at line 2486?
I wanted to test my SupVi "serial line control" (under Labview Version 6.0)
and than this error occuried.
Thamkful for every help,
Ruth.
p.s.: I consulted the ni homepage, but the presentated solution was to general.
(2,684 Views)
Ruth,
You are right, I could not find any information on this error either. First, please try your program in LabVIEW 6.0.2. This has many fixes for issues and might solve this one.
Second, if this does not work, then we will need to dig into the code to see where the error is happening so we can get it fixed. This would be better handled by an e-mail or phone support request. You can create on by going to www.ni.com/ask and choosing the e-mail or phone option. In the description of your issue, please include as much detail on your application as you can and if you have done any debugging to narrow do
wn the VI that has the issue.
Randy Hoskin
(2,684 Views)
