Labview internal error at DSTM.cpp
  When I start LabView v8.0.1, I get the message (see attached file).
 The thing is, LV didn't crash the last time!!
  I closed LV when I finished working with my VI and there were no error messages....did it really crash? Is this a false alarm? It's happened a couple of times over the last few days....Do the message comes up every time there is an error or is it that the first time I didn't do anything to solve it?
(3,036 Views)
Hi emerino,
LabVIEW probably did not actually crash last time you worked with it.  Sometimes it crashes, sometimes it's just an internal error.  If you will select the "Investigate internal error now" option, it will have you create an error log file and email it to support.  If it's not too much trouble, please do this next time it happens so R&D can have more information that will help improve LabVIEW.  Thanks!
James R.
(3,022 Views)
