Labview interface for HTML web server
I need to interface an embedded microprocessor running as a web server via HTML to Labview. Specifically the LabView application needs to send the microprocessor commands and receive it's responses via HTML. Has anyone done this before - any ideas?
(3,142 Views)
Just an idea - you might check out the TCP functions on the Communications subpalette. They should allow you to communicate to and from the standard HTTP port on your web server. Disclaimer: this is how I would start it. I have not done anything like it before.
2 cents
(3,142 Views)
bnheather,
You may want to look at the LabVIEW Internet Toolset. This toolset includes HTML VIs for reading and sending HTML documents. Get more information here.
Randy Hoskin
http://www.ni.com/ask
(3,142 Views)
