Labview interface for Arduino
Hi everybody,
here I am, I need help at the Level of firmware LIFA (LabVIEW interface for Arduino). I have a project at uni that consists of running a few servo-motors (6), which are connected to my board Arduino Mega 2560. In order to communicate the board with LabVIEW I download the firmware LIFA, my goal being to allow LabVIEW-arduino communication, to be able to generate the PWM needed to run my engine.
the problems are:
- after downloading the firmware on the board, I can not emit any PWM signal from my turntable (the code attached)
- for servo motors, no signal, no PWM, no response.
I specify that I oscilloscope all these signals.
Attached: the code to have a pwm signal and that to run a servo motor.
thanks for the help
(4,283 Views)
Accepted by topic author Xavinana
Try LINX from makerhub or from digilent
LIFA is not working anymore
Or you can use labview arduino compatible compiler from aledyne to download labview program to arduino
You can find all of them in VI packcage manager
Kudos and Marked as Solution == Thanks
(4,252 Views)
thx for the Answer. i downloaded LINX. should i need to download the driver NI VISA? ou it can work without ?
(4,217 Views)
