Labview installer failed to communicate with NI
I am currently in the NI Package Manager trying to install the "myDAQ Software Suite" for a class. The progress bar gets more than 75% complete and I get a pop-up:
It does not matter whether I select yes or no, but this immediately appears:
I have clicked 'try again' only for the latter pop-up to appear again, but this time it only takes a few seconds into the installation process and the "NI Update Service" pop-up does not appear first.
I have also tried multiple different wireless connections and an ethernet connection as well.
I am an administrator on my PC.
There are no "ad-blocker" types keeping me from installing this software.
Any help/ guidance would be appreciated. I would love to do this over a zoom meeting/ video chat if possible.
(2,074 Views)
What happens if you click the link to update Package Manager?
What appears under "installed"?
Have you tried downloading this from the website or just through Package Manager?
(2,035 Views)
I have some questions about your installation -- something looks strange, to me.  [Sadly, even with the release of NIPM for Installation of LabVIEW and its components, LabVIEW Installation is still, except in the "simplest" of circumstances, a challenging task best left to Experts ...].
  • Did you try to install this on a Computer that already had LabVIEW installed (and running properly)?
  • Was the installed version of LabVIEW LabVIEW 2019, 32-bit?  [I ask as this is what I have installed, and when I just experimented with trying to install the myDAQ Software Suite, it took me to the 2019 version of the Suite].
  • What Install Options did it give you?  [On my PC, LabVIEW and LabVIEW CDS Module were both checked-and-grayed out, NI-ELVISmx and Circuit Design Suite Education were pre-selected, and LabVIEW MathScript Module was an option].
  • I noticed you showed an installation for JKI VI Package Manager.  You should not install anything else that is not obviously part of the myDAQ Suite at this time -- it can only mess you up.
You might be in the unfortunate situation of having corrupted the LabVIEW installation on your "test" PC.  However, it is not too difficult to remove all NI Software and do the entire Installation over again, from scratch.  Come back here if you need more help doing this.
(2,019 Views)
Did you try to install this on a computer that already had LabVIEW installed (and running properly)?
•I’m not sure if these are the same thing, but I did have multisim downloaded last year and running fine. I have since then deleted it
• I’ve tried a couple different things. I have installed the 2019 32-bit; did not work, then I deleted it and tried to do the 2019 64-bit (I do have a 64-bit computer but I was told that I would only need the 64-bit software if I needed more storage, which I don’t think I do.)
• I don’t remember exactly what install options it gave me, when I downloaded the software installer I just left the options however they were checked by default.
• This might be my problem but all of my classmates have not encountered this problem
Thanks for your help so far!
(1,994 Views)
Underneath installed is the NI package manager program.
And yes, I have tried downloading the software installer from both the website and from the package manager.
(1,990 Views)
After I click yes or no and the error pop-up appears, it then shows that I have 28 items installed??
(1,987 Views)
In general NI Package Manager is a failure!
I have more than one ticket open due to problems NI Package Manager has caused in my lab, and it's been a month trying new things and emailing log files to NI
LabVIEW 2020 is the worst release I have ever seen, and I have been using LabVIEW since LabVIEW 5.1
=== Engineer Ambiguously ===
(1,945 Views)
