Labview increasing memory usage
When running Labview with TestStand, the memory usage of Labview increases every run of the sequence. Is there any reason for this?
(3,874 Views)
Are you calling a C/C++ function directly from within a vi? Are you using a Call Library Function Node?
JLV
(3,874 Views)
It sounds like a memory leak.
(3,875 Views)
Yes, I can undrestand it is a memory leak.
Can Anybody advise me on how to debug or fix the problem. I have altered the code to make it as memory efficient as possible.
(3,874 Views)
Do you use LabWindows-CVI or do you call any C++ (dll) using TestStand?
Do you use System Exec.vi in the Labview code?
(3,874 Views)
Possibly not releasing all variables from memory.
Check to see if the increase is constant every time you run TestStand.
(3,819 Views)
