Labview generated executable is not able to run the application trigger using cmd
Hi
We created a applicaiton in Labivew and used cmdline to call one java application.  In normal development mode it is working fine and with a button click we are able trigger the command line java application.
We tried creating a final executable of Labview application and copied the  java class file and also installed JDK on the client machine. When we try to run this executable and the cmd line java application is not getting triggered.
We tried with simple c compiler generated exe from cmd line, but the behavior is same.
Can someone help how to create a Labview executable with the cmd line applicaiton working from the executable.
Regards
Kris
(2,993 Views)
Hi Kris,
what's the path you are trying to call your JAVA file from in the executable?
Use a OneButtonDialog to show the path…
In case that's the problem: Use ApplicationDir as base path to find your JAVA file!
(2,971 Views)
What errors are you getting?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,968 Views)
