Labview file conversion toolkit
I have many files in the Labview 5.1 version.
I cannot open it in my Labview 8.5 version.
The source code in labview 5.1 should be modified to suite the present requirement.
So i urgently need the labview file conversion toolkit.
Please attach the file for download.
I am using windows xp operating system.
Please help me at your earliest.
Regards
Grugh Mike
Success is Everything !!
Message 1 of 10
(6,450 Views)
Hi grugh,
there is no toolkit for conversion of LV5.1 files to newer versions. You need a LV-version from LV6 to LV8.2 (?) to upconvert those files.
Or you upload your file in this thread...
Message 2 of 10
(6,439 Views)
i need to convert a main program which has almost 50 sub vi, so how can i do that?
Please reply at your earliest.
Regards
Grugh Mike
Message 3 of 10
(6,431 Views)
Hi grugh,
"Please reply at your earliest."
It doesn't help to ask for fast help as this is a forum of volunteers... It's your own problem of work task organization!
"convert a main program which has almost 50 sub vi"
It doesn't matter if it's one VI or a full hierarchy of VIs: the way to upconvert them will be the same! See message #2!
Message 4 of 10
(6,425 Views)
ok thank you
I am hereby attaching the .rar file of the vi's.
Please do convert it into the 8.5 version.
Regards
Grugh Mike
Message 5 of 10
(6,416 Views)
Accepted by topic author Grugh_Mike
Hi grugh,
have you read what I wrote?
There's an upconvert thread for such request...
Message 6 of 10
(6,412 Views)
am exteremely sorry.
Anyway thanks for the reply.
Regards
Grugh Mike
Message 7 of 10
(6,403 Views)
kudos given Smiley Wink
Message 8 of 10
(6,209 Views)
I'd like to convert these three files from LabVIEW 9.0 to LabVIEW 8.5.
Thank you
Message 9 of 10
(5,986 Views)
Thank you
Please post to the Version Conversion Board
Message 10 of 10
(5,984 Views)
