Labview fatal error in fpsane.cpp, line 399
arg!!!
i have LV 8.2.1 on my laptop. LV is crashing very often without telling me why. but this time it actually did:
fpsane.cpp, line 399.
never had this problem with LV 8.2.0 (upgraded only because had to reboot computer).
what was i doing at that time:
after changing some typedefs on enums, rewired a few nodes on a (very) simple subvi, that includes only but 4 enums and a case structure.
then i went preparing night food for baby. came back and had error.... of course, did not save main project...
should i go back to LV 8.2.0?
... And here's where I keep assorted lengths of wires...
(4,057 Views)
Hi Gabi,
could you post the code so I can reproduce it
Best Regards
Benjamin
AE National Instruments
(4,030 Views)
sorry i cant, this project is proprietary.
But i think i figured out the problem: the FP of the main vi has minimal screen size set for a 17" diameter screen. my laptop has only 15. then when i maximize the window, the size of the FP is smaller than its predefined minimum. it does work most of the time, but everytime i do 'undo', or create/delete a property node, LV resets the FP size to its minimal preset value. LV crashed quite often. now i cancelled the minimal size, and it seems much more stable. In my office computer i have no problem, but it is 8.2.0 there, with 17" panel...
(4,015 Views)
Hi Gabi,
could you send in the error report located in C:\Dokumente und Einstellungen\"Username"\Eigene Dateien\LabVIEW Data\lvfailurelog\*.log
Best Regards
Benjamin
(4,011 Views)
here i send you the relevent logs. the last one is the fpsane one. had to delete name of vi and folders.
thanks for looking into it.
(4,000 Views)
Hi Gabi,
your problem is a known issue in LabVIEW 8.2.1.
We working on to fix the problem, we handle this issue with the ID: 49ECOCGF
Best regards
Benjamin
(3,938 Views)
thanks.
well i just got 8.5, so thinking to switch over, unless major drawback.
(3,934 Views)
