Labview executable is giving a error message after installation when i run the program
I have created a labview executable using LV6.1,after installation in a PC which does not have LV,it gives me a error when i run saying "An error occurred when loading "counter group config.vi".How do i solve it
(2,807 Views)
In the Build Application or Shared Library in the source files TAB, you should include the Library zadvdctr.llb which you will find in the vi.lib/Daq directory.
Then build all again and run the installation from the scratch
There are 10 kind of persons. Those who understand binaries and the others.
(2,807 Views)
You need to install NI-DAQ on the new pc. A built application does not include hardware drivers such as NI-DAQ, NI-GPIB, etc.
(2,807 Views)
