Labview executable error - system cannot find the file specified
Hi
I am trying to create a stand-alone application and I'm getting the error message below:
"System cannot find the file specified"
This error message occurs when I run the setup.exe. Does any one know why this is happening? I've also attached the error message screenshot.
(3,637 Views)
It sounds like the installer is not able to find the executable.  Did you build the executable first?
"Should be" isn't "Is" -Jay
(3,629 Views)
What type of hardware are you using? What do you mean by stand alone? Are you using any RIO device? (Just trying to understand)
(3,624 Views)
Hi Jeff
Yes I built the executable app first before building the installer. Is it wrong to do it that way?
(3,609 Views)
I meant labview executable. No I'm not using any RIO devices.
(3,606 Views)
