Labview.exe error
When I try to upgrade Labview 6i to 6.0.2, I always get a "Labview.exe error and will be shut down by windows". It is a Windows 2000 system. I have 5 other systems that are identical and have not had this problem on any of them. I have reformatted the hard drive and reloaded Windows 2000. I have removed all devices. The system is just the motherboard, C drive. a: drive(Floopy), and 😧 drive(CDRW). I have tried all types of configurations and still get the same problems. I have attached a DRWatson fault log.
(2,606 Views)
Those error logs are hardly ever usefull in support. There may be a problem with the hardware. Have you tried moving a harddrive from a good computer and put it in the bad? If so, do you still get the "Labview.exe error and will be shut down by windows" message? You might also try putting the bad harddrive in a good computer. Either of these methods will be a fast way to isolate the difference in what appears to be identical computers.
(2,606 Views)
