Labview example for data capture using 5102 scope card
How can I program a Labview Vi to control, and capture a waveform using the 5102 scope card. I need to be able to set it up to continually capture a waveform (Channel 1 and Channel 2) when triggered on a rising edge of channel 1 and then store the data on disk automatically, then wait for the next trigger.
Any help or tips as to how I could do it would be helpful.
Allan
(3,015 Views)
Allan,
Please find the attached zip file that has some useful LabVIEW examples with scope 5102
Zvezdana S.
(3,015 Views)
Labview 6i has an application with a name that includes 5102 and sync ("
5102Sync.vi"?). It allows one channel to act as the trigger for both channels.
Requires a cable between the PFI connectors (NI sells for $45 each). It
works, but if you have to take more than about 1 sec worth of data at a time,
be prepared to wait for results. The 5102 can only dump a completed
acquisitions worth of data at a time.
Neil
Please remove the "nt" for legitimate email. Thanks!
(3,015 Views)
