Labview errors
Hi, when I try to execute some example program present in labview driver package of Tektronix Function Generator and Agilent Oscilloscope an error message appear:
"Old VISA Open in TKAFG3xx Initialize.vi->example2.vi"
"Old VISA Open in hp548xxa Initialize.vi->hp548xxa Getting Started.vi"
What is the problem? I'm working with Labview 6.1 Base package and the drivers have been downloaded from ni site. Thanks in advance for your help.
AM
(3,216 Views)
Do you have the correct address for the instruments specified? What is the error code?
(3,216 Views)
Also, make sure the instruments are detected using MAX (if they are GPIB instruments). You can use MAX to determine the appropriate resource name.
DiegoF.
(3,216 Views)
Ok I have fixed the problem! The instruments were initialized with "GPIB::x" instead of "GPIB::x::INSTR", where x is the instrument GPIB address. Thanks
AM
(3,216 Views)
