Labview error -200686 & -200687
Hello I am trying to use the CO Pulse Time daqmx VI to control the high time and low time on a NI 9482 relay in a 9174 chassis.  When I try to write large value high or low times I am getting errors 200686 and 200687.  It looks like these errors are related to attempting to write a value out of range for the time count.  The error message says this maximum value is about 107 seconds.  Is there anyway to change this or am I limited by the hardware?  Is the CO Pulse Time VI not meant for longer count duration?  Thank you for your help!
Message 1 of 1
(2,201 Views)
