Labview driver
Hello all,
Does anyone know where to download the labview driver for the signal syn HP 83640L?
Thank!
(4,171 Views)
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=863
You could also simply use the Find Instrument Drivers inside of LabVIEW.
(4,167 Views)
Hi Crossrulz,
Does the driver of 83650A support  83640L?
Thanks very much!
(4,164 Views)
I would think so.  Typically when Agilent adds the letters, there's some performance tweek or firmware update.  The SCPI commands should not be changing.
(4,158 Views)
You need to look at the differences since the L is a CW generator. The driver for the A model may not support all functions. You can modify the driver and add anything that is missing.
(4,153 Views)
Thanks very much!!!
(4,143 Views)
