Labview doens't open
Hello all,
I'm, new in Linux, but I must prepare a machine with LabView for Linux.
I have de centOS 6.2 already installed, I already intalled labview, the icon appears in the applications menu, but doens't starts, can somebody help me on this subject? Why can't I open Labview?
Thanks in advance, best regards,
Paulo Carmo
(3,115 Views)
I'm afraid this distribution is not supported by NI, see this.
Hope this helps
Epictetus
Antoine Chalons
(3,110 Views)
Hello again e thanks for your fast reply.
This time I installed the OpenSuse, but when I try to install Labview the system is saiing that I have not the repositories to install this software.
What shall I do?
(3,091 Views)
hello Carmo,
what version of LabVIEW do you use?
if you try to run LabVIEW from a terminal, like "xterm", what is the output on the commandline?
kind regards,
Robert H
NI germany
(3,065 Views)
🙂 An other problem
Step by steo, very slowlly, but I'm getting there
This time I already have Labview in a Linux machine, I have other linux machine only with Run-time (both with OpenSuse).
I made an application on my first machine, but this application doesn't run in the second one. It says that :
"There is no application installed that can open files of the type executable (application/x-executable)."
(3,045 Views)
Hey Carmo,
i never heard this before. do you have an example application, which i could test on my machine?
regards,
robert
(3,019 Views)
