Labview deployed to singleboard computer with windows OS
Hello, I have develop a labVIEW program using the USRP and IMAQ modules/toolkits and build an executable on my desktop computer. Also, will probably have to install the run time engine on the SBC. Is it possible to open the executable/installer on the single board computers (like the LattePanda or the sbc-b68)? Thanks.
(3,781 Views)
Accepted by topic author cdiaz093
Well as long as the system has an x86/64 compatible CPU and runs standard Windows (not one of the Mobile versions, known before as Windows RT or Windows Universal App platform)  you should be fine installing the compiled LabVIEW executable with the according runtime engine on those boards.
If it has a different CPU, or uses one of the Windows Mobile/Phone/Universal App platforms then you are out of luck. They do not allow to install apps from anywhere but the Windows store and in the case of an ARM or other CPU can't even run the LabVIEW software.
What might be challenging though is to get the IMAQdx software driver running. But never tried that one.
Rolf Kalbermatter  My Blog
(3,727 Views)
