Labview crashing during long program
I am having a problem with Labview shutting itself down after it is
running for a long time. I am running a test that takes about 6 hours.
I am confident that it isn't my code that is causing the failure since
it just executes the same loop over and over with different permutations
of data.
I was just wondering if anyone else has experienced similar problems and
if anyone has any suggestions?
Thanks a lot
Jenni
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,645 Views)
At the Users Group here in Portland some time back, there was mention of an
internal PC timer that times out as it fills it's bit frame. Call LabVIEW
tech support for exact info. It has plagued several people running very
long programs. It may be related to your situation.
jbuglar@my-deja.com wrote in message <7nn0qt$sl8$1@nnrp1.deja.com>...
>Hi,
>of data.
>Thanks a lot
>J
enni
(3,645 Views)
