Labview crash when using text tool on control name in cluster
Hello.
Ive run into a bug in LabView 8.0.
It seems that when I select the name (with text tool) of the first control in a cluster (vi included) the name of the control changes color from white to black. Then I try to select
another controls name and LabView crashes.
Asked a collegue to verify the bug and it appears on his system also.
Could you please look into it? Its kinda nasty.
Attached the vi where the bug appears (only a cluster).
Cheers
//Beckman
(2,782 Views)
Works fine for me. LV 8.0.1 on Mac OSX 10.4.6 on a Dual G5.
Lynn
(2,771 Views)
Hello Beckman!
I couldn´t reproduce the behaviour you described. Please try to patch LV and see if the problem still occurs.
The location for the maintenance release is here:
http://digital.ni.com/public.nsf/websearch/D5C32AD00F07D7D586257110007B54D2?OpenDocument
Cheers.
Ashwani S.
National Instruments Sweden
(2,760 Views)
Ah.. I forgot to say that I'm running Lv Linux 8.0. I'll try the patch.
Thanks !
Cheers
//Beckman
(2,752 Views)
