Labview compatible low-budget multiplexer
Hello everyone,
I am trying to set up a device to automate some of the measurements in our laboratory, which will save a lot of time. Since I am on a budget I would need to know a very cheap source for a multiplexer that can be programmed with Labview. Can anybody recommend me sources?
Ideally I would need one 30 to 1 multiplexer and another one that can do 10 to 1. However, I could also create smaller batches if that would save money.
Many thanks,
Ralf
(4,088 Views)
Hi pannepanda,
what kind of signals do you want to multiplex?
To multiplex 30 signals you need 5 bits of information, so an USB6008 might be sufficient to drive your "multiplexer"…
(4,080 Views)
The signals are analogue. I just had a quick check on the USB-6008, it has 32 slots. Wouldn't I need 2 of them to multiplex 30-to-1 and 10-to-1, or are there any tricks to avoid this?
Ralf
(4,066 Views)
Hi pannepanda,
when you talk about "multiplexer" I thought you would need an external device that does the switching, so you would only need to communicate with that external device. The easiest possibility to drive a 30:1 multiplexer is by using 5 DOs…
Please state your needs with clear descriptions!
Do you need a DAQ card to measure up to 32 analog signals? Call your local NI sales representative!
(4,054 Views)
That is what I need, a device that switches between 30 signals. I am a chemist and not very familiar with the jargon. But anyhow, I image that I will need 30 input plugs and one output plug for my device. I only know the USB6008 from a short intro to Labview but I think that most of the plugs are only for a certain type of signal, is that right?
(4,046 Views)
Hi pannepanda,
yes, each input pin has it's name and purpose - see the manual. The USB6008 is only capably to measure 8 analog inputs…
You really should call your local NI office! In Germany you should call 089-7413130…
(4,041 Views)
Hi pannepanda
The USB6008 is not suitable to multiplex 30 analog signals. It's spec is here...
https://www.ni.com/en-us/support/model.usb-6008.html
Basically it can generate and sense low voltage analog and digital signals with a counter function. It has no multiplexing capability.
NI has a vast selection of data acquistion devices to choose from. As a starting point you need to know the voltage range, current and frequency of the signals you are trying to multiplex. Then contact NI Smiley Happy
(4,035 Views)
