Labview compatibility with SPSS
Hi
I am a student and I write my project.
A part of my project is to take data from sensors and analysed via SPSS program..
I read that is possible with the Active X function.
Have someone of you any example or link that could help me.
Thanks in advance
(3,979 Views)
You will need to provide more information than that to get help.
What is SPSS?
What sensors are you using?
Where does ActiveX come into play?
(3,966 Views)
Spss is a computer application that provides statistical analysis of Data.
I am using an Ultrasound sensor,
I want to connect Labview with the external Spss program.
(3,961 Views)
Activex support for LabVIEW is very good and if you have the documentation for SPSS, you should be able to connect and send information to it. Please refer to our website for more information in how to program with ActiveX:
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/computer/plat-ole-mnu.htm...
On a side note, you should also look in LabVIEW, in special in the Mathematics, Signal Processing palette and see if that would be not sufficient for you. LabVIEW improved a lot in the latest 3 releases and have a comprehensive number of functions for advanced math and statistics.
Also, if you would prefer to use equations, you could use Mathscript for your application. If you have some m-files available for analysis, this could generally be used in LabVIEW.
If you can't find the analysis that you are looking for, let me know. Maybe I could in converting to LabVIEW. Always remember to tell which version of LabVIEW and which OS your are using.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,934 Views)
