Labview code error in Scan Engine mode
Hi yash,
@yash99 wrote:
any idea how to transfer file to cRIO  ?
When you create an RTEXE from your RT code then you can add additional files to the build spec. Those additional files will get transferred to your RT target, usually in a "data" folder next to the RTEXE. This way it's very easy to transfer your TDMS file to your cRIO target!
(Again: do the cRIO/Realtime basics training material…)
Message 11 of 16
(1,426 Views)
Standard file transfer method between Windows and a Linux bases cRIO is WebDAV or sftp after enabling SSH access.
Cf. this reply
Regards, Jens
Kudos are welcome...
Message 12 of 16
(1,421 Views)
Thanks a lot for advice and help! Really appreciate it !
Thanks a lot.
Message 13 of 16
(1,409 Views)
Thanks a lot.
Message 14 of 16
(1,407 Views)
Tks a lot for help and advice,really appreciate it !
Thanks a lot !
Message 15 of 16
(1,392 Views)
Thanks a lot !
For the longest time, I couldn't figure out how to quote someone in my reply so everyone could see what I was replying to.  The quote button is actually in the edit toolbar!  (It's the quotation mark.)  It used to be a button on the bottom.  I think it was "Reply" and "Reply with Quote" or something like that.
Just FYI.  🙂
Bill
CLD
(Mid-Level minion.)
Message 16 of 16
(1,382 Views)
