Labview can only reads values from Arduino
I have a Arduino UNO board. I have to make a program in C or C++(any other text based Code) and upload it into Arduion board.
Is it possible to upload my labview code to Arduino directly?
I have an Ultrasonic sensor and as i'm not Good at TEXT BASED codes i've to search on different forums for code in C++ and after that i can only read values in Labview.
I think LabVIEW can only read the serial data.
Please help me if i'm wrong in this concept.
(4,083 Views)
Hi mangesh,
did you ever google for "labview arduino"?
(4,081 Views)
Thanks GredW,
I have googled most of the things about Labview Arduino but not getting that there is a way to upload my Labview code directly into Arduino.
Regards
Mangesh
(4,075 Views)
Well, can not download the Arduino code developed in LabVIEW ARM microcontrollers exist if they can download the code, for example LM3S8962 ARM Cortex is a microcontroller that can do this job
(3,981 Views)
some interesting links
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209852
http://chess.eecs.berkeley.edu/eecs149/sp09/docs/374931b.pdf
https://decibel.ni.com/content/groups/ni-embedded-module-for-arm-microcontrollers/blog/2013/09/23/labview-arm-lm3s8962-dashboart
(3,977 Views)
@tom,
I appreciate your response.
I was playing with arduino around a year back.
Since arduino is the low cost solution i preffered it but unfortunatly we can do basic serial tasks to it through LabVIEW but cant upload the code directly in it.Smiley Sad
Thanks again
(3,952 Views)
estimated ManLD not worry, Arduino is a practical solution but always have more powerful processors such as ARM and now MyRIO to work with embedded systems, best regards
(3,930 Views)
