Labview can not create a control for the "data" Input of DLL
I got a source code (C#) for the function CAN_FrameStream.
is it enough code to tell?
Message 11 of 14
(839 Views)
Sadly, it is not enough. Do you not have documentation on what to put in these variables? Is your original question solved?
Message 12 of 14
(823 Views)
It is a CAN communication for CAR. we only got the DLL, C# original code.
Then text code call a function " NI_CanFrameStream" in DLL(maybe):
($Result, $FramesRead, $FramesReponse) = NI_CanFrameStream($DUT_CAN04, $baudRateCAN, $data8061CANArray, $arbID, $NumberOfFrames, $HexDisplay,$CANTimeout);
(They are running well to return the 3 values in Text code normally)
as you can see, I have put the inputs value beside the Constructor, and plus the "data" value that we discussed yesterday.
I hope that running the vi with Values, then "frames" output may return an array with 3 parameters ($Result, $FramesRead, $FramesReponse) as well.
I will run the vi in couple of days, and let you know if it is solved.
thanks.
Message 13 of 14
(797 Views)
Thanks .it has 8 bytes; do I need to place 8 sets?
Message 14 of 14
(794 Views)
