Labview basic
Dear forum members of Ni Instruments. I have one problem, it looks like easy, but for me realy difficult.
I need to compare 5 arrays and choose 3.
If any array exist the biggest and smallest element of the 5 arrays, choose the another 3 arrays.
The Vi attached. I am using Labview 8.0.
Thank you in advise.
Sincerely yours,
Harutyun Melikyan!
(4,337 Views)
What should happen if the smallest and largest element are both in the same array?
(4,331 Views)
Here's one simple solution (LabVIEW 8.0). Modify as needed.
Why don't you want to use any "structures"?
Message Edited by altenbach on 12-09-2007 10:45 PM
(4,320 Views)
Dear Altenbach, thank you for good question.
I have 5 arrays, each array contain the 551 elements, which like this:
        for example  -0.1, -0.15, ....., -54, ...., -0,15, -0.1 Each array, have one minimum(-54)
                                                     Next array is about similar -0.1, -0.15, ....., -56, ...., -0,15, -0.1                                                    (-56)
        3rd            -0.1, -0.15, ....., -55, ...., -0,15, -0.1                                                   (-55)
        4th            -0.1, -0.15, ....., -55.15, ...., -0,15, -0.1                                             (-55.15)
        5th            -0.1, -0.15, ....., -55.17, ...., -0,15, -0.1                                              (-55.17)
I want to delete2(or choose 3), I mean the array in which the minimum is -54, and array with -56 delete. And choose another 3 arrays. Later I will average 3 curves, which is the nearest each other, and another 2 which are far, I want don't use in averaging process.
I think now I represent my problem with more details.
(4,319 Views)
Dear Altenbach in my explanation process I understand my mistake.
I have 5 negative curves which we obtain from 5 arrays. each array element start from for example -0.1, -0.2, ..., -53.12, -54.15,-53.15 ..., -0.2, -0.1. In this array the smalest element is -54.15. I have like this 5 arrays(curves). I want to delete 2arrays, in which exist of these 5 negative elements, but I want delete the arrays which have minimum and maximum. For example:
the 1st array minimum is -54, 2nd -53, 3rd -55, 4th -51, 5th -56. I will delete the arrays, in which exists -51, and -56 elements, which are the minimum of these 2 arrays correspondingly.
Sorry for my bad explanation, I sure now I explain my problem correctly.
Best regards
Harutyun Melikyan!
(4,307 Views)
Dear Altenbach thank you for your great help.
Here attached the JPEG, which explain my problem fully.
With best regards
Harutyun Melikyan!
(4,285 Views)
Maybe something like this?
(4,277 Views)
