Labview based application not load using Windows XP in Virtual PC on a MAC?
An application we want to use, Smart Vibration Sensorversion 2.0.0.46a, uses Labview runtime 7.1.  We are attempting to run this application in Windows XP using  Virtual PC verison 7.0.1 a Mac Powerbook G4 laptop.  The application appears to start to load, but then disappears.  No error messages are presented.  The application vendor, UpdateInternational, Ph:303-986-6761 :Steve, suggested that I contact NI to see if your product was compatible with Virtual PC or if you had any suggestions.  Any ideas?
Jeff
(2,988 Views)
Hi Jeff,
LabVIEW is supported in Virtual PC however the DAQ driver are not supported. See the following Knowledge base for more information:
http://digital.ni.com/public.nsf/websearch/55B080D2FCBBD20786256895007C5BED?OpenDocument
Ankita
(2,971 Views)
