Labview applications
Hi All,
I am having some doubts regarding the use of Labview.
I am very new to labview and if you can support me to clear my doubts it would be great help for me.
Can you please tell me what is the use of labview? Give me some applicatios so that I can go through that.
How do I use labview to aquire the accelration data or any other data?
(3,654 Views)
I may not be the best to answer but. I find labview very good at data aquisition and signal processing. t
Look at the examples folder (under help menu) for whats possible, the examples folder will use have examples of data aquisition which you can work with).
I hope other people will answer this thread who are a bit more elloquent than me but hopefully it gets you started into looking into labview
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,648 Views)
Thanks for your support.
I have gone through some examples but I need some more information.
Which type of hardware used for data aquasition like accelration,velocity etc
How do I do the connection of sensors with the hradwares?
(3,644 Views)
For hardware you have a number of options PXI rack setup,PCI cards in a PC, devices connected to USB etc... pretty well any kind of solution you can think off. The sensors are then wired possibly through some kind of signal conditioning setup to the cards (or wirelessly if you wish). Browse the ni website for specific hardware, have a look at the configuration advisors if you have a specific application in mind
 Labview interfaces with these devices easily
hope it helps
(3,640 Views)
I would suggest you to search what ever your queries in the NI site. And also you can contact an NI support Engineer for knowing and selecting the hardware depending on your application.
(3,638 Views)
Find your local sales rep and have them come out and do a demo for you.  They can help with your initial questions.
http://www.ni.com/domestic_sales/
(3,620 Views)
