Labview application exe has many open cases
I have an application of which sporadically find running 10, maybe 40 times. I can only close the application exe in windows task manager.
Have you got any ideas what can cause this to happen?
Kind regards,
Balzs
(2,263 Views)
Hi Balzs,
Did you enable the executable to run multiple times in parallel?
(2,242 Views)
Thanks, i'll give it a try 😉
Balazs
(2,190 Views)
As Gerd said, applications typically only have one instance (Unless you enable multiple instances, a rare, non-default option).
Do you really have 10+ instances of the same toplevel program running in parallel or are you saying that if you try to end it, it will start over? Could it be that your program launches N reentrant instances of a certain subVI? We definitely need more details.
If you cannot stop the application, I assume you have a coding error. How is ending the program handled? (stop button? Panel close event?) Is the code trapped somewhere in an infinite loop?
(2,178 Views)
Guess: You spawn some dialog window that you close without exiting so it continues to run in the background?
Qestit Systems
Certified-LabVIEW-Developer
(2,146 Views)
